anti roll bar bushes
hi does anybody know what size the hole should be on the front anti roll bar bushes on a 2002 vrs? i need to replace mine the bar is 19mm but looking around they do a 19mm and a 17mm to fit same bar???
any ideas:rotz:
any ideas:rotz:
You need the 19mm bushes as the ARB has sleeves that the bushes sits around. VRS owners have found that if there ARB sleeves have worn or broken then the 17mm bush option can be used with no sleeving. You only need to do this if your ARB sleeves are shot.(which is common on higher mileage cars)
Ok cheers for that!!
