05 Octavia Wiper Problem
I there,Ive a problem with my Octavia at the minute,
Its a Skoda Octavia Elegance 2.0 TDI Estate.
My wipers wont work at all. I got water in my fuse box under the bonnent. I have dried it all out and replaced the fuses but my front wipers arnt getting power at all.
Im basically wondering where all the fuses are and relays are for these? And the number of the fuses and relay(s)?
I know fuses F16 and F31 are to do with wipers but thats all I can see in the manual!
Do the stalk arms give trouble as I have sorted the fuse box and everything else is working.
Now Ive read that theres a relay under the steering wheel.
"Remone the panel from around the pedals (2 torx screws and 2 integral clips), look up towards the right and you will see the relay plate. Bottom row furthest to the right is where the wiper control unit is, it is around 6cm long and 3cm high."
But I cant find a relay that size.
Any help would be good thanks.
Try the fuse box beside the steering wheel too - open the driver's door and pull off the panel on the side of the dashboard to expose another fuse box. I don't think the relays are there though, but it might be easier to find the relay box by tracing wires from that fuse box...
