camber adjustable top mounts
I have been offered camber adjustable top mounts for the front suspension, with adjustability of upto -2 degrees.
they said £150, and usually retail for £297
Is this worthwhile mod, or should i just wait and buy fully castor and camber adjustable top mounts at a later date.
my original plan was audi TTlower control arms that allow an additional -0.5 degree camber around 400+fitting
or
the morego power grip wishbone for an additional(but not adjustable) for -1.75 degrees camber £495+fitting
or
these will be combined with the WALK
Hi Simon,
me too had considered the TT lower control arms because of their lightness.
IMHO (and for my pleasure), WALK is already a big improvement from standard setup.
Have it on, as soon as you can :) !
I dont want to get it fitted until I have decided what I am going to do with getting additonal camber othewwise i will end up paying twice for labour.
im thinking the increase in castor from the walk, and camber from the top mounts should be a good combo.
The top mounts adjust upto -2 degrees camber. i think standard camber is -0.8, so its not a massive difference even when set to maximum. Once fitted i think i will be heading to wheels in motion for a full geometry set up from them
