Aircon problem
Hi there,I have a problem with aircon on my 02 fabia estate tdi.I had it on diagnostic and it showed the following faults:
code 01596 Motor fresh air recirculating valve (V154) short with ground
Motor fresh air recirculating valve blocked no voltage.
I found out that code 01596 stands for the AC/heater recirculation flap motor.
Does anybody know wether it is a common problem in fabias?
How difficult is to replace the recirculation flap motor?Has anybody done this before?
Would appreciate comments,help.
Thank you.
Fairly common. Not a DIY job unless you have a full service manual, and are prepared to rip out half the dash/ centre consul. Probably worth having the EVAP sensor replaced at the same time.
I have been quoted £300 inc. VAT (fitted), to replace both, and it will take a garage about 3 hours to do.
