Ebay intercooler ?
My DV is on the cold side by the throttle body :D
The seller tells me the pipework will miss a strut brace :)
57mm UNIVERSAL PIPE HOSE & INTERCOOLER KIT FULL UPGRADE on eBay (end time 05-Sep-09 01:01:49 BST)
this is the one i used, you will also need to buy a 90degree bend and the map sensor pipe,
i did mine for about £234
Mind you that ebay one listed in top of thread does have the map sensor pipe and all the pipes are rolled and therefore could be angled to suit the VRS without buying any other parts. So could be a good value mod. As stated only issue is, can't see the fitting holes or brackets.
N7EJA - maybe contact the seller and see what he says.
