a little help :) "doorsides"
You are supposed to remove only the outer part of the "handle". The clips that hold the outer part are quite stubborn, and require a bit of violence before they give up.. When the outer part of the handle is of, you will find two T30 screws under it which you must unscrew. The rest of the door panel/card/side is held on by plastic clips if I don't remember it all wrong.. The clips have a tendency to break when you pull on the door card, so buy some before you start taking the car apart :-)
Hope you get it sorted!
thx for the help jonA :)
