rear windscreen jwasher
Should the rear jet washer only spray upwards? As mine now follows the movements of the rear wiper arm and Im sure it only used to spray upwards before?
Thanks Matt
only a half dead kitten for you ;)
they should spray upwards :thumbup:
Info
more info
further info
Edited by Jonny5ive
Make sure its actually moving before you buy the repair kit, on mine the jet had somehow moved so when the wiper was moving it was cutting the jet stream off making it look like it was moving.
In the end all I had to do was pull the jet out with a pair of pliers and adjust its position.
Yeah, I've had that too on-and-off since a bikerack collapsed and took out the plastic bit around the nozzle. It's just a push-fit, so can be adjusted with pliers, as has been said. :thumbup:
Thanks for the info:thumbup: I apologise to any kittens lost in the making of this thread!
