VRS Dash Lights Come On HELP!
Pulled up at work and the abs and the hazard light below it on the dahs both in yellow have come on for no reason and are staying on? i do not have a handbook so cannot read further can anyone tell me why they have come on and what i can do to turn them off . I want to get this sorted as i want to sell my car in the near furture.... Cheers Jake:confused:
you may have a fault with the abs system if the light is staying on. you need to get someone with VAGCOM to read the codes to see if it is just a sensor fault or something else.
http://briskoda.net/diagnostics-vag-com/vag-com-owners-map/80992/ is a good place to look for some help (most are happy with a couple of beers so a lot cheaper than a dealer scan)
i got both these lights a few weeks ago ;) abs wire had been rubbing off the drivers side front wheel. You need to get it scanned with VAGcom and that will give you an idea where the fault is coming from.
