Ignition Part Numbers?
Hi, I've got a 1995 Favorit that I'd like to replace the dizzy cap and rotor arm on... the only problem is, nobody seems to know what fits?!
The car is injected and has a rust red cap and rotor, much like Bosch parts but they seem to be OE as they are from the same manufacturer as the distributor. Can't remember off-hand what the manufacturer is, but it begins with an M and is from the Czech Republic.
Has anybody got any comparable part numbers that I can use to source the correct parts?
I've never had any trouble getting Favorit parts from any motor factor. The usual sources (Motorparts, Quinton Hazell etc.) all list the Favorits and I've never found their catalogues to be wrong. Where have you tried?
