xenon sensors where?
Where on the suspension/wheel are the xenon level suspension? grounded the car out on speed bumps in the service station on the way back and xenons now seem high.
Sensor on the back axle. At least that's where it was on the Fabia. Pretty certain that's where it's located on most/all OEM systems.
Steve
There are two. IIRC they are both on the LHS.
The front one connects to the lower arm and the rear one connects to the trailing arm
It's likely to be the front one that's been dislodged. If you look carefully you can sometimes see where the original position was
HTH
are they in a position that can be scrapped by a speed hump?
