is she worth it
my favorit haz sat with a nakerd timing chain for a year
took the hed off to see what the cylinders are like and the is sum rust in ther is it worth geting the fix on not
no
Depends what you mean by "some rust". A little surface rust won't be a problem - I've run engines that have been standing for 3 years which had a thin dusty covering of surface rust and they were fine. If it's bad, then it won't be any use, though. Have you got a picture?
+1, don't worry about a bit of surface rust, but if there is any pitting or deep corrosion then chuck the engine in your next door neighbours wheelie bin when they are at tesco...
ok thanks
