Handbrake cover fitting
Hi, Having a bit of trouble removing my plastic handbrake cover to replace it with a vRS item. How do I get the old cover off?
JON
There is a slot underneath the handle. You stick a screwdriver blade into it and then pull in the direction of the dashboard.
You may run into a complication, in that some of the Fabias had a straight handbrake, whereas some of them had one with a kink in. You have no way of telling which you have until you get the cover off, but the vRS cover you have may or may not fit. I hope it does. Good luck.
