Err Columbus voice control without MFSW
Do you actually need the mic connected before the VC option comes up?
Tried it with the other Sunday. It should still respond to pressing the i button. :(
Its on the RNS under , after the update.
Any further clues?
We were a bit short of time so can't quite remember.
We used the bluetooth mic connected to the mic-in on the RNS and then connected the mic-out to the bluetooth kit. The fact is though that the voice control should work when you press the i button irrespective of mic or not.
Just upping to 266* fw should already give you an option for voice control in the setup menu (the normal setup menu, not the hidden).
Coding it by VCDS will make you able to use it. (but you need a mic connected to the RNS/Columbus).
That is what I did and pushing the button made the lady ask what I wanted to do next :P
I am back to the 1100fw at the moment, because of the same probs Simeon has. (flat battery). Hope to flash it back as soon as I have my newer gateway installed.
Not on mine.:(
