Bolero Traffic Info
Tried setting up the TIM for specific times and according to the manual it will record any traffic reports in the 90 minutes before and 30 minutes after the set time when the car is parked with ignition off. Never any available when I get in the car at set time. When I switch the ignition off it selects a station for them which you can change at this point so appears to be working this far. Anybody got this to work?
I've not got to grips with the Bolero yet but I did make a point of asking the salesman who was going over it with me how you turned the traffic reports off. The car that I scrapped interrupted the station I was listening to with the traffic reports (usually from 30 - 40 miles away on a 6 mile journey to work) and I could not find out from the manual how to disable this infuriating feature.
Should have mentioned normal traffic reports work fine when driving and switched on (i.e. TP showing). The recording feature also works but only for reports I've already heard when driving - i.e. I can replay them. I'm trying to get it to record reports before I get in the car.
I have had it working
I have it set for about 07:30 and 16:00, tuned to local BBC and independent stations, both seemed to have worked ok - usually better in the morning get in the car and tend to see the 07:12 and 07:19 traffic reports.
Pretty cool ;o)
Not sure what I'm doing wrong! Did you do anything other than check the active box and set the time?
