The Octavia Bass Tip Is Great - Thanks !
do you know who makes it?
would any other brand be compatible with the changer...?
  • Replies 56
  • Views 7.8k
Seem to recall it was Grundig...I did find a site (edworthy's, I think) that had changers compatible
with the head unit, so a bit of searching might reveal a head unit capable of controlling the changer.
Or, stick an amp or two behind it... :D
Rob.
It's a Panasonic changer but it has a Blaupunkt type connector so you'd have to sort that out.
I know the Sony site do a compatability chart thingy; as Rob says the HU is a Grundig.
Well it was a beautiful day yesterday and decided that I would listen to Radiohead's Hail.... which prompted me to play it in the car ........and then I found the stanley knife !!
Definite improvement in the bass - looked at the flap cut and " widened the flap with duct tape on all three sides then tucked it in to membrane .... Hope that this will improve the potential water problem by producing an overlap .
I would discount the potential airbag problem because there are drain holes holes for the door space on the outer side of the lower door seal - therefore there can be no pressure problem .
My personal preference is to have the driver's side only tweeter disconnected .
major discovery (IMO)
the bass tip works.. no more crappy foamcup/membrane
replace front and f tweets with
sony 1726 component upgrades sounds 200% better
rears replace other day with sony 1331 xplod - need some bass blockers on - got but not fitted yet..
major discovery no.2 (IMO - but you might know)
want preouts
get a pre out adapter from blaupunkt - plugs into the blank yellow connector on the back of the headunit and give f+r pre out..
looks like a trip out for my trusty punch 60i and the 10" sub:cool:
Rob.
is a grundig/ blaupunkt hybrid according to my local stereo shop..
but the panasonic changer doesnt work with anything else - even panasonic head units... (damn wanted an excuse for a fold away tv...and the pana's are so nice!)
Originally posted by ffelan in this post
want preouts
This is what is planned for my amps - Ian wasn't sure if it would
work due to the HU not being pure Blaupunkt, but if someone
else says it works, then that's a good sign! :D
Rob.
