The Octavia Bass Tip Is Great - Thanks !
Thanks for the tip listed in the FAQ below (and someone else for mentioning it yesterday - stopan1j?)) on improving the bass by spending absolutely nothing !
I'd already replaced the front speakers with Infinty's but the sound still distorted so I just thought it was down to the head-unit being poor.
Its amazing what you can do with a screwdriver and a Stanley knife - the sound quality and depth (due to better resistance to distortion ?) is at least 50% better.
I also tried unplugging the rear tweeters as suggested but am too busy turning the bass up to notice now !
Good one !:cheers:
http://briskoda.net/forums/misc.php?s=&action=faq&page=5#3
  • Replies 56
  • Views 7.8k
I shall be investigating later this evening ..... hadn't spotted that tip before. Is it new?
Over in Ireland we only get a single disc blaupunkt as standard.I suppose the bass trick still applies.
Regards David
Not guiltty M'lord - you wont catch me cutting the membrane - find my system quite adequate - must be an age thing - but agree that I have heard good sound in quite basic cars - the last 2 Fiat Puntos I hired seemed really good if I remember.
John
My membrane is already cut to feed the speaker wires through, so I'm guessing it's
not airtight anyway. Am I the only one to find this?
Rob.
I had the front Bass unit ( HA HA ) out of my vRS the other day to see whats involved in this mod, but all there was behind the speaker was a foam cup.. Can this be removed easily???
I don't really want to take this foam out if it will damage the membrane. Advice will be most helpfull..
Dazz
Foam cup? Is this like the "carpet pudding" over the rear speakers?
I'd advise getting rid of these, but I don't know if the door ones are attached
to the membrane as mine didn't have them!
Rob.
Its a foam backing moulded to the shape of the speaker....
It might be an new thing in the Octavia...
Speaker location in the rear is crap anyway....
And I'm thinking about installing a Alpine
Component setup... but how to get at the front door tweeter
is anybody's guess......
Dazz
Think it might just be an vRS thing!
The speaker location in the back is good if you like to get the full effect but don't want
your parcel shelf in ;)
Front door tweeter is pretty easy to get at I think, though I've never done it. Just a question
of gently levering off the plastic cover with a screwdriver...
Rob.
Anyone with a recent vRS , shed any light on this?
cheers
Dazz
Had mine replaced with a Sony component set, the tweeter does just prise off, do it gently though I broke one of the clips. Big sound improvement with the standard HU. Then I replaced that with a blaupunkt. Wow what a difference, now all I need to sort out is the vibrating internal door trim.
That Dynamat stuff will probably be useful for damping the trim though it's not cheap! :D
Rob.
without sounding completly dumb....how do you remove the front speaker grills
Gentle prising with a screwdriver... :D
Seem to work for most things!
Rob.
So anyone have this Foam stuff then???
Also is it possible to fit a new tweeter in the door and run the cabling down with removing the door panel..??
Dazz
It did cross my mind that the speaker cabling could do with being upgraded.
However, for the most part this will require removing lots of carpet and trim,
as you'd have to essentially reloom it.
So yes, you probably could do it without removing the door trim, but it'll probably
be harder in the long run! Also, your recabling wouldn't stop there...
Ian might be a good person to advise on this, as I seem to recall him mentioning
putting some "extra cables" in his in preparation... :D
Rob.
I'm not adverse to such things, and it is pretty easy to do...
The difference in sound quality and quantity is worth it..
:cheers:
Dazz
any chance of a couple of pictures - finding the whole membrane cutting thing hard to visualise... ?
Don't think there were any pctures even from the Vortex days.
Anyway, if you were to remove the inner door panel you would see a plastic lining covering the door effectively sealing the window mechanism.
When you remove the front speaker (and foam cup thingy) put your hand in the hole (ooh err) where the speaker was; you should feel the plastic lining.
What you ned to do is cut a flap using the hole as a template; the flap should be like opening a tin can with tin opener. It should be still attached at the top.
I think the reason for this was to give the speaker some damp prtection (:confused: ). You can of course just cut a hole.
By cutting the linig you open out a great space for air to move and hence better sound.
I'm sure there's a more techincal description but I think you'll get the drift.
Hope this helps.
Cheers.
Adrian.
Thanks Adrian,
I will give it a look tonight..
K
So I presume I'm supposed to leave the foam cup thingy out when I put the whole lot back together ?
Yep!
Adrian.
I live in Central America and here rain a lot. Is this can be a problem??? Can the speaker get wet????:confused: Or can water come inside the car?:eek:
In Manchester, it rains a lot too...in fact, it's raining right now... :(
Anyway, my covers both have holes in them for the speaker cable to go through (and
this was done by Skoda!), so I'm wondering if the plastic really does anything...
Rob.
I removed the foam cup thingies today and guess what ? :confused:
There was no plastic membrane behind them ! :eek:
And one of them was a little wet ? :(
It has been pretty rainy recently and I use a pressure washer to hose the car when washing it - hope the lack of membrane doesn't cause me any problems. :rolleyes:
But the bass is bangin' ! :D
