Gearbox oil
Where to find hole for changing oil in gearbox on Felicia 1,3 lx from 1997?
Do someone have picture?
Follow the speedo cable - it's the bit at the back of the gearbox (back of the car side), and there's a 9mm headed bolt you need to remove and then pull the speedo drive out of the box to fill it. This is also the level checking area, the oil should (IIRC) just touch the bottom of the nylon drive gear when it's in place. - you should be able to see some oil in the bottom of the hole if it's about right.
I found it :)
Thank you very much.
