ECU Update / Parameter change TDI
:)Reading through the Octy 1 forum I found information about HOT STARTING problesm with Tdi 110's due to a requirement to achieve 260 RPM during starting before teh injector Pump will allow fuel into the engine.
Is there a way to modify this parameter using VAG-COM or other to get around this problem?
NO.
In theory, it could be mapped out, but there is no coding that VCDS/Vag-Com can change. The solution is to change the battery
Fixed by lubing the gears in the starter motor instead - all working well since then
Thanks for the help
