MFD 2 Issues/autochanger..Help needed please.
I have fitted a MFD2 some time ago and had the interference when using the auto changer. So i did as Vrs Stu stated on his great site and got a connector block and moved around cetain wires but it has not fixed the problem. When usins the auot changer i hear a crackly/whine which appears to be related to the RPM. The i pod bit works ok as does the MFD2, any ideas anyone? ps i have had it coded by a local dealer so thats all ok. :thumbup:
thanks guys and girls ;)
Do you get a crackly/whine when the engine is not running? when you say it appears to change with the rpm, it's sounds like your picking up some inteference from the engine electrics.
I do get some interference with the engine is off, but whilst driving as the speed increases/changes the whine changes pitch.:confused::confused:
  • 10 months later...
Hi there, did you very resolve this issue as I have the same problem.
Many thanks
