Some Questions
Hi,
I've got some questions about some mods i'm thinking of doing in the near furture:
Removal of the second air pump, Heard that Forge do a blanking kit to carry this out?
Forge or other TIP (Turbo intake pipe) , what difference does this make?
Bypass the N249 valve , seen this is a comon mod on seatcupra.net , has anybody done this to the mk1 octavia vrs and what difference has it made?
Anyother info would be a massive help.
Jay_w
Hi,
Jay_w
why remove the secondary air pump would only do this if i was removing the cat as this does a job..
forge tip will just make the turbo spool up a little faster and is a good mod todo
bypass the n249 i would leave it as it is only need to mess with these things when going big turbo.
hope that helps :thumbup:
