Engine sometimes races off-load, Ideas?
2007 1.9Tdi:
When driving gently at, say 30mph in third, the revs stay up when I take my foot off the accelerator.
If I then depress the clutch, the revs rise; sometimes to 2.5K then back down, sometimes to 3.5K rpm!
If I depress the brake pedal, the revs drop, presumably because activating the brake servo has an effect on the fuel/air supply side.
My guess is a leak somewhere in the air supply to the engine.
It's booked in to local Skoda dealers on Friday, but there is any chance that there might be a loose pipe etc etc which I might find myself and fix? I'm happy to fiddle, but am not taking a spanner to the Roomster while it's still under warranty!
Thanks,
Stuart
Common issue with accelerator, dealer should be aware by now, mine was - see this thread: http://briskoda.net/roomster/high-tickover/136054/
Thanks. They were. They ordered a replacement for tomorrow, as well as pointing out that Kwik Fit had fitted the wrong sized tyres a few days ago.
Took it back to Kwik Fit, who apologised and I left with new tyres, and the 'racing engine' problem gone!
Farmers Skoda had also said that diagnostics had also reported a possible brake sensor (ABS sensor?) problem.
I wonder if the original fitting of tyres had affected the sensor, and the 2nd fitting rectified it?
Certainly, there's no fault at the moment.
Stuart
Stuart
It's possible thats the case.
