Water Build Up Inside Widows
Hi there wonder if anyone could help. Have noticed that water is building up on front and rear windscreen inside car. Its a real pain as have to use a rag to get all water off. something wrong i imagine! no water inside car to my knowledge. any suggestions appreciated.
cheers
fergus
Certainly sounds like you have water in there somewhere. Check the carpets aren't damp, and check the spare wheel area as that can fill with water due to leaking rear washer (a common fault).
Check the pollen filter, might be dead leaves blocking drainage somewhere or might have leaky window letting in water.
Is it caused by condensation on the inside of the glass ?
(or from your title you may like to suggest to your 'Widow' that she sees a doctor ;))
You need to use the air con or climate control to clear it :)
Tried that this morning but with it being 2 degrees outside it won't let it run. Says something in the book about the AC not operating below a certain temperature to avoid it icing up IIRC.
That's right, mine wasn't running this morning. It's around 2deg C it stops.
