Yeti light problem
Tried to answer in the thread you linked to :) Hope your dealer sorts this out for you very quick!
Hi I took it in on Friday - they connected it to computer and got a list of faults.
4 errors on n/s H/L
6 errors on o/s H/L
4 errors each on both tail lights
1 error on columbus areil
1error on drivers door switch
and another undisclosed error
currently sitting at the dealers until it is sorted out - well it was Friday the 13th
Regards
Mike
4 errors on n/s H/L
6 errors on o/s H/L
Regards
Mike
Hi Mike,
thanks for the update, hope they get to the bottom of this problem quickly. Be interesting to find out the cause, the light fault codes still make me think controller but the aerial.:confused:
Sounds like a bad earthing prob to me....
Heard from the dealer today - they say it is a control module and are trying to find one in the Czech Republic (gulp) - I wonder how long that will take??????
Regards
Mike
Been told today that I need part No 1K0937086C to fix the problem
Initialy I was told it would probably be here on the 14th Decamber:eek::mad::( after ringing the salesman it should be here this week:confused:
I shall live in hope
Regards
Mike
Sorted - they fitted a new cpu but fault persisted so after talks with skoda they fitted a new headlight unit.
Regards
Mike
Regards
Mike
Hi Mike, thanks for reposting and good news that you have this issue sorted at last.
Hi
I spoke to soon - the warning lignt is coming back on, it comes on after driving a short distance but not every time and I can not see a light out. I spoke to dealer and have been told that about 5 other yetis have the same problem, all diesels - the fault sensor is too sensitive and skoda are trying to sort a software solution. The saga continues
Regards
Mike
Sorry to hear that Mike, hope they don't take too long finding a fix.
Hi
Hi Killy,Is this on the first startup of the day. Warning light is on within 50 mts. Switch off then switch on again, the fualt is cleared?
Yes Warning light not showing but it can be up to 500 mts then warning light comes on and sometimes there is no light out on car but at other times my front O/S headlight goes out!
Like it did on my way home from work tonight Yes the original fault is back
Getting a bit fed up now
Regards
Mike
Regards
Mike
Well there may be 2 of us!
Software is now being released to dealers its on the VAS software disc 15.38. This is for the rear light problem. Skoda are investigating the headlight problem, but no fix as yet.
Well there seems to be a fix - I got it back today and it seems to be ok. But time will tell
Regards
Mike
CORRECT - No fix for headlight yet - fault back this morning
Regards
Mike
Killy,
I have been away for a fortnight sorry to see you still have the front light issue (I think I still have it too). As a side issue, doe's your Maxidit loose its settings on occasions?
Regards
Ray
Killy,
Regards
Ray
Hi Ray.
I hope you had a good holiday. I have been advised to use the lights on manual until skoda find a fix, I have been useing them on auto. What settings do you refer to, more info please.
Regards
Mike
Hi Ray.
Regards
Mike
Unless someone at the airport car park has been messing about, My lights, light up for the coming/leaving home fuction when I had left them switched off.
Thinking about it, I bet loads of people gave it the once over :giggle:
Had a new twist this morning. Previously either the warning lamp was on, and we have had the "front o/s headlamp" message and the headlamp has indeed been out. This morning, no warning lamp or message but at first I thought the o/s headlamp was out, then I realised it was just tilted right down. But then it did go out! So did the usual switch off engine and restart and it went through the usual tilt/swivel self-check and was fine.
It's going in on New Year's Eve so we'll see what they say.
Mark
Mark
I'm beginning to think being only able to afford the SE was maybe not so bad. It looks like a software problem eeek hell knows why they didn't get this fully working before launch... Hope you get it working soon...
Jerry
Hi Car going in tomorrow for headlight fix - the fix is a new controler in the headlight, they are fitting two, one in each.
Regards
Mike
Regards
Mike
Keep me posted Mike. :thumbup:
1
Edited by Andymod
