felicia rev counter
Looking to put a rev counter in the 98 1.9d pickup. Found a new one for the slightly later model but unsure how it will wire in. Does anybody know whether it connects to the w on the alternator or the ecu. A wiring diag. would help, can`t seem to find one.Any one got any ideas?
the rev signal comes from pin 1 on the ecu, but is also connected to the W terminal on the alternator, it should already be wired up for it
Is it a seperate wire that goes to the alternator then tom? What colour wire would this be on a 1.3?
My rev counter has never worked right and I have even tried a whole new wire from the ECU to the back of the dash as well as a new dash pod and rev counter but it still doesn't work!
So the wire that comes from the alternator must provide a variable voltage to the rev counter along with the signal from the ECU right?
Phil
the above only applies to the diesel models phil.
Ah! In which case... I appologise for the off topic-ness and swiftly exit :D:thumbup:
I guess I will just live it then! :rotz:
have you tried a different ecu phil?
No I havn't. Not had one to try so havn't. Plus not sure if my vag-com and cable would be able to do the jiggery pokey for the immobiliser etc.
Phil
so long as it's a registered version it will be ok... does yours have a bosch or siemens ecu?? i'll have a look for one
