16705 fault code??
My boss has fault code 16705 which is causing limp mode.Car holds back at approx 2300rpm and doesn't boost properly.
I have cleared all codes and this is the only one that comes back.It does point to the 'Hall Sensor' G28 and i have even swapped mine over to see if it clears the problem,but it doesn't.
Any suggestions?
TIA.
G28 refers to a crank sensor fault
Crank/Hall sensor but it didn't solve the problem.
This might help: 16705/P0321/000801 - Ross-Tech Wiki
Maybe the plug or the wiring to the plug is dodgy.
Surely there's an opportunity to wangle some sort of bonus if you fix this for him!!
I have the same fault on SWMBOs Fabia 1.4 TDI. The car runs fine, but is a bit difficult to start and has a flashing glow plug light and steady engine management light.
I have changed the crank sensor twice and the fault goes away for a while and then returns.
