Net Programme
Who can enlighten me as to where each of the three nets fits for the boot net kit?
I have this (and VBF) and cant work it out.
I should add it's an estate.
I had not contemplated the side storage bits.
ATM I have one (like a closed V) across the boot width about 10cm behind the rear seats and one covering the rear 1/2 of the VBF floor.
I am sure it is all wrong though.
Will do, once I track em down.
The curry hooks work a treat, but I am wondering what else I can catch in the boot.
Hey Foo
does this help?.... ?koda Accessories
Jon
It does a little. I helps me realise that the VBF I have means I cant fit them like that.
Dammit.
I have them kind of like that - the 'base' one is much more taught over the VBF, and the 'umbrealla' one is right at the back though.
There is a third, mystery net as well, as big but slightly different to the 'base' one, it might even be another 'umbrealla' one thinking about it as it has hooks in the middle of the edges.
To be honest I didn't realise there was a "special" way to fit these :confused:
I tend to move them around depending on what I need them for. Either side, or both sides, flat on the floor, at the front, at the back etc.
If you really stuck I can post some pics tomorrow, but there're really not that hard to fit, OK you may need to stretch them bit at first, but after some playing you'll get the idea. Also sometimes you need the plastic hook like clips, others just the elastic loops.
