Alloys for felicia
Hi, does anyone know whether these alloys would fit my felicia?Tyre Width: 195 Aspect Ratio: 40 Load Index: 80 Speed Rating: W: max 168 mph Rim Width: 7J Rim Diameter: 16 inches Offset: 25 Number of Studs: 4 Stud Diameter: 100
what is the centre bore size??
The centre bore is 64mm
apart from the offset being slightly too wide you will need a spigot adaptor to take the 64mm bore to 57.1mm
speedrating is slightly lowbut that aside, most 4 wheels/rims, less than 6inches wide, intended for opel(vauxhall?), vw, audi or bmw will fit right on, et around 354/100 center hole 57,1 is about the most common wheel of allet 25 means the wheels will move outwards 10 mm each side, which in sweden is illegal, but nobody checks, i think it would look nice. center bore 64, is that what you measured or ? it is more than any standard 4/100 wheel i think, renault twingo is closest to that
The wheels are second hand and i emailed the person asking for the centre bore size and 64mm is the number he gave me, but he also said that he has some rings 64mm-54.1mm
