DAB window aeriel
Anyone tried a window mounted DAB radio aeriel any good and is the roof mounted combined aeril much better or same, thanks. :confused:
I think rooboy has the aeriel through the windscreen type. May be worth sending him a PM :)
Yes I have a glass mount DAB aerial. You can get them here as they are direct from the manufacturer. www.panorama.co.uk and the guy you need to speak to is [email protected]
I did consider the Blaupunkt combined roof aearial but at around
Try the roof mounted one, its the best thing out there for DAB, especially in marginal DAB areas. I've installed about 10 now and they work impeccably well. Head linings are easy to drop on Passat estate.
Its well worth the money if you are keeping the car for sometime. Also if you go for the windscreen one there is no guarantee that it'll come off in one piece of you need a replacement screen.
Andy
