Octavia I GLXi a few codes
Hi guys, hope you can help.
A couple of months back my SDi was written off, and i've recently got hold of a 2000 V reg 2.0 GLXi cheaply. Been running fine for the last few weeks, then the check engine light came on. My brother in laws mate came over and scanned the car with VAG-Com and it's flashed up a few codes. Would you mind having a look over the codes and let me know if it's anything serious or something that can be DIY'd fairly easily as funds are a bit tight as per usual this time of year. The check engine light was off again when i tried it the following day.
Address 01 -------------------------------------------------------
Controller: 06A 906 018 FH
Component: 2.0l R4/2V MOTR HS V06
Coding: 00011
Shop #: WSC 00000
7 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
Theres also a few codes for the central locking but I think i know how to sort those by reading a few other threads here.
Any help is greatly appreciated.
Neil
With intermittent codes, it's usually a case of clearing them, using the car for a while, re-scanning and seeing what codes reappear. Looking at your codes it would seem that replacing the temperature sensor and investigating the misfire on number 2 cylinder would be a start. Misfires on the 2 litre petrol are quite common, it could be the plugs as they are a 40000 mile change interval and not easy to get at, leads are common and have metal caps at the plug end which could short to the cylinder head, also whilst there it may be a good idea to use some silicone grease where the leads attach to the plugs. We usually get our silicone grease from the local Ford dealer. Only when the misfire and temperature readings are sorted and the engine is running as it should do will the catalyst have any chance of working correctly.
Thanks, I know im pushing my luck, but do you know where i can find the part number for the sensor? And what would be the best plugs to put in?
Thanks for the help
Neil
Have you tried looking in the usefull part numbers thread in the Octavia 1 forum?
