Will a 02a solid flywheel fit on the Fabia vRS?
my mate who used to work for vw and now works for a bmw specialist garage reckons the 02a solid flywheel should fit the fabia vRS???
I wouldn't of thought so, IIRC the 02A is a 5 speed usually found in petrols. MK3 golf gti's I think
Edited by GSPK
i ran a billet spec smf in my fabia,if i were you i would find someone with a smf fitted and have a listen to it before you spent any cash on one as they are a bit of an aquired taste
need an 02M flywheel to match the 02M clutch & gearbox. :) 240mm from memory, and I think the 5 speed flywheels are 232mm, or smaller.
I too run a billet clutch too - and would agree that the noise is an interesting conversation point with other drivers!!!!
run with a vibra technics dogbone mount and things get even more....er.......interesting :rofl:
need an 02M flywheel to match the 02M clutch & gearbox. emoticon-0100-smile.gif 240mm from memory, and I think the 5 speed flywheels are 232mm, or smaller.
Doesn't happen often! ;)
So wot car uses this setup as standard?
