engine light on...got codes need help..up date.sorted
hi i had my codes cleared the other day as engine light was on...it came back on ..this is what it said
...[17705.....p1297..pressure drop between turbo and throttle valve.]..............[.17704....p1296..error in mapped cooling system[check temp-sensor and thermostate]..
..[16486....p0102...mass air flow sensor g70 signal too low intermitent]...............can any one help and tell me what i need to do ......any info would be great full....thanks and all the best for the new year :thumbup:
Edited by vrsjaw
17705 is a pain in the ass to sort out as it can be any number of things, first off I would do the cheap things like cleaning the throttle body and checking all the big and little hoses around the engine and turbo system for splits and move on from there. If you do a search on here for 17705 fault code it will bring up lots of threads.
17704 is usually the coolant temperature sensor, but can also be the thermostat playing up. The sensor is located on the right hand side of the engine as you look at it and plugs in between the engine block and one of the coolant hoses. You will need to remove both the plastic engine covers to access it. Check that the multiplug to it is plugged in properly and that the wiring looks alright, if both those things are ok then it probably needs to be replaced, you need to replace the O ring seal at the same time.
The MAF fault code could just be a dirty MAF, it's the bit between the air box and the hoses going to the turbo, take it off and clean it with Carb cleaner, if you are still having problems with it then try running the car with it unplugged and if the car runs better then you need to replace the MAF itself
Happy New Year!
Edited by chicken_eyebrow
hi , 17705 is a very common one , ive had it and took me ages to sort it out , plus it can cost alot to sort to . Heres my story to the code hope it helps http://briskoda.net/forums/topic/140568-ive-cured-the-17705-etc-codes/page__p__1760027__hl__ive%20cured__fromsearch__1entry1760027
the 17704 is a plug in the cooling system which is easy fixed . get the un-graded one which is a green one
and the 16486 i think will be the MAF sensor . Best way to see if it is , is to unplug the MAF sensor and drive it , but with you having the 17705 code you might not notice it , also by un-pluging it , it will turn the traction control light on .
if im wrong by what i said , im sorry so please correct me if i am .
hope this helps
nice one ....where can i get the up rated tps from......and how will i no if my thottle body needs changeing...thanks again
also the car feels abit slow some times....and my car back fired and that what made the engine light come back on........
will temp switch be ok? .http://cgi.ebay.co.uk/SKODA-OCTAVIA-TEMP-TEMPERATURE-SENSOR-KIT-GREEN-4-PIN_W0QQitemZ170415891388QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item27ad9423bc
Edited by vrsjaw
That's the one and at a good price. Their application is a bit misleading as the Octavia from 1997 to 2001 has a different plug to that one.
av bought one.....so i hope that helps with my probs............thanks for the help guys :thumbup:
i dont think the TPS will cure car feeling abit slow some times....and my car back fired .
sounds like the MAF sensor could be on the way out , if the car is pulling and stoping like your jabing the brake with your other foot .
to be honest you cant tell if the throttle body needs changing its just a chance it will cure the 17705 code , which in my luck it did . if you follow my guide and it doesnt sort it then it will be the throttle body .
normaly 90% of the time the 17705 code is a new throttle body or a second hand one if you trust the person your getting it off .
hi to day when i started my car it ticked over ok but when i went to set off it woudnt rev just poping and then it was ok ....
the revs were going up and down so i un pluged the afm and it stopped........cheers :thumbup:
Edited by vrsjaw
Not stricly true, It's usually a boost leak, very few people with this problem on the site have changed a TB too cure it.
It does seem too be caused by re-mapping some times, but a lot of people just live with it as it's a bit of mystery as too why it happens
mine is standard no after market parts fitted yet.....just paid £81.85p for new afm....just waiting for the tps and thomosat as my heater gauge stays at
quarter way .....then once av fitted them it just the pressure drop i have to sort out......the car has had a little knock to drivers side front bumper
not bad but could it of damaged the intercooler? the car really doesnt feel like a turbo....is any one near la14 area cumbria who can look at my car il pay?
also will it be ok to drive my car with other faults after av fitted the new afm as i dont want to damage the new afm.....
thanks for all the help guys :)
hi put the new afm on car was ok went for a drive and came back the revs started to go up and down so i un plugged the afm and was ok ....
..i guess the afm has gone again ...its from vw dealers not a after market one can any one help plz
bump plz help :'(
all sorted thanks to awesome gti.... :thumbup:
what was wrong?
some pipes that go under the inlet and the rocker ...dipstick pipe....tps.and throtte relined...runs spot on..now remap time :)
