Rear Screen Washer
Its not working :thumbdown:
I filled it up and the front ones work fine (although one of the nozzle thingys has come off - where can I get these?)
Rear washer just doesnt wanna know, anyone know why? or where to start looking to fix it?
The front nozzles are probably a dealer job, but shouldn't be too expensive I imagine. As for the rear washer, can you see a puddle under the car when you try and use it? It MAY help identify which of the following joints has gone: connection at washer pump behind NSF wheel arch liner; at connection in bulkhead behind filter box; at connection behind trim where back of NSR seat meets NSR door opening; connection at rear wash/wipe pump. I say 'may' as the undertray makes it hare to distiguish between the first two on the basis of spills alone, but it will be one of those four locations... :)
