Climate controls
I have a new fl vRS - for some reason there is no lighting on the round controls that adjust cabin temperature (dual zone climate) - you can see the temperature numbers but being RHS they tend to be on the LHS of the control and not easily visible - only a problem at night of course !! Is this correct or should they be lit ?
Sounds the same as mine without going to look at the car (its cold outside you know!).
However, if you adjust any of the climate settings these appear on the stereo screen for a couple of seconds so you don't need to look at the controls too much.
There is a menu on the non Maxidot Bolero control panel for illumination levels of the controls plus IIRC the panel light dimmer affects them as well. Snowing at the moment so keeping inside! Check out the on line manual.
Thought the Bolero menu was for the stereo controls only ?
