Glowplug circuit fault
Had a search but only really found this result (click me)
My dads Fab VRs had the emissons light come on on Sunday while driving around town, he said power is normal (so not in limp) and when we looked in the manual it says it should come up with 'emissions workshop' which it didn't!
Sooo drove to work and back on monday and tuesday (50ish miles each way of A roads, little bit of M-way and some twisties), told him to give it some stick thinking it could be a clogged EGR, no change, so scanned it last night, which gave this error
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 35-00
Cleared it, turned engine on and light had gone off. I think it stayed off on the way to work but came on early on the way back.
The car itself is an 06 plate which has done around 105k IIRC.
What do people think it is? Glow plugs gone and need changing?
We have the same 'fault' on our MK5 Golf (105 PD) but it includes all four cylinders:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC G000SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9253489
Coding: 0000071
Shop #: WSC 00000 028 00001
4 Faults Found:
P0671 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 10110000
However despite these 'faults' the car starts first time every time even with the freezing temperatures we have been having lately, let the glow plug light go out, turn the key and it starts instantly.
However there is no emissions light showing on the dashboard, so for now (or until it actually starts behaving inappropriately, it is being ignored)
