How often should Skoda fabia be serviced?
How often do Skoda fabia's need to be serviced?
Depends if you're on variable or fixed servicing...
I swear by servicing mine every 10k with Mobil 1 ESP 5w-30
Kev
10K or 1 year which ever first.
I didn't think the Fabia was available to run on variable servicing (due to no oil sensor in the sump)?
You're probably right, i cant remember off the top of my head lol.
I usually service every 10k with a longlife oil.. Now on 102k miles, tempted to take the cam cover off to check what the cam wear is like with this oil setup..
Kev
I'm sure my driver's manual makes reference to long-life/variable servicing ...
It probably does, but none of them have the oil condition sensor to support (look for the QG0 service code on the service schedule sticker or in the boot).
Oil change at least every 10k regardless of time, and a full service every year. New brake fluid every couple of years and coolant every five IIRC. Cambelt (if you have one) is every 60k or four years - this might contradict your service schedule if you have an older Fabia, but is current advice based on failure-in-service...
I did toy with putting in long-life oil and getting it serviced once a year when I was doing about 12k per annum, but decided against it. Do about 16-18k now, so get the oil changed every 6 months.
HTH
Will have to have a look at the stickers to satisfy my curiosity then. :) I remember reading the manual and not really seeing anything on fixed-interval servicing, just variable-interval, and thinking "I'll just do it every year/10k miles, whichever comes first ... what harm can it do?" (the same as fixed-interval). Didn't know about the coolant life - I'm sure the manual said life of vehicle (there again I may be remembering it from the manual of another VW vehicle)...
Edited by martinch
I give mine a service every 6 months regardless of miles
10k or yearly.
The oil is more than good enough to last that long today.
Ben
Hello and Welcome to the Forum :hi:
If your car is a Fabia vRS then it is more than likely to be on fixed servicing (10k or yearly). If it just a normal Fabia it my be this fixed type, however it may be on variable servicing, this is where sensors check the oil quality and tell you when it needs changing (between 10-20K miles).
Whichever it is you should get a spanner symbol on the dashboard when you start the car and this tells you that you need a service, however it's also best to check the service book first. One other thing, if you have a Diesel and service it yourself or get a local garage (non-dealer) to do it, you MUST use the correct special PD oil, (there is a list in the sticky thread on here)
I servise my fabia 1.9 tdi (chip 150hp) every 10k kilometers , i drive fabia every year more than 40k kilometers, thats 4 times in one year that i change the oil , and 2 times i change the interior filter. onece a year change the fuel filter..... and the intake filter youst clean , becouse i have K&N panel filter...
10000miles or 1 year which ever comes first :thumbup:
Yup, you're right - I had a look at the sticker in the service manual and it indeed says "QG0". The service manual is clear if you read it, but it's not if you skim it like I did (if there's no possibility of it being on QG1/2, they should IMHO have printed the service manual without mentioning it - I know that would have upped costs, but it'd be a lot more user-friendly).
Coolant every five IIRC.
The G12++ coolant is supposed to be "life of vehicle" according the the Haynes manual, it's not mentioned in the service manual, and the driver's manual says the coolant system does not need maintenance under normal conditions. If you're using some other coolant, then it's supposed to be replaced "at the recommended interval", although I couldn't find a definition for that..? Am I missing something?
Edited by martinch
Since I got my Fabia VRS 4 years ago from new, I've had it serviced by the Skoda dealer and wonder if there is any real benefit in the dealer service rather than my local garage?
There is no problem have the car serviced at your local non franchise garage, as long as they service it using OE parts and have VAG.com to scan for faults. I would ask them if they are familiar with VAG cars, PD oil etc. before they work on my car. Some people are also obsessed with with having Full Skoda Main Dealer Service history for their Warranty but this is not necessary anymore. The warranty conditions say that the car should be serviced according to the Manufacturers schedules, that is all. Shopping around at other VAG franchises is also worth doing as well as they sometimes have special offers/half price labour rates.
Non at all now it's out of warranty.
Personally i would take it to a good independent VAG specialist and save yourself some money.
Thanks to the EU Block Exemption Regulations, it would be illegal for a car manufacturer to specify the all servicing must be carried out by a franchised dealership for the warranty to be valid. :)
