Can someone help please?
I am looking for a picture of the underside of the Mk 1 skoda octavia.
If anyone knows or has one then can they please post it up?
I am a little confised as to the jacking points for a trolly jack and were I can put the stands. this is why I need the pic of the underside of the car. so the places can be marked clearly.
thanks
billy
Hi there,
i have octavia mark one and will take picture tommorow and sent it to you. Its dark at the moment.
What i normally do, instead of jackin the car on the seals i normally jack my octavia on solid part of subframe, it is a solid place and nothing will bent.
Regards
cheers mate, that will be ace as i cant do anything now, I need a good place to jack it up so I then get the stands in too.
billy
I remembered I had these on Facebook from when I had my zorst done, if there is anywhere I can jack and put the stands can you please paint it on and repost?
they are not very good as I was in a hurry to get out from under the car lol. I cant seem to find any on the net.
billy
I have circled a few points I was thinkin about. what you think
Front and rear?
is it ok to use the trolly on these with half a Yellow pages to protect it?
being carefull about the cables, is this were the mech lifts it?
Billy all the points in your last 3 pics are ok.
For the front I tend to use the front of the main chassis members you circled to jack up on, then when in the air put axle stands under the front subframe bolts again where you circled
For the rear I jack up on the rear wishbone mounts(where the brake cable route under) then when in the air but axle stands either under the wishbone bolts as your pic states or the rear beam between the whiteline bar .
P.S I posted the Hub seperator tool to you today, hopefully you get it tomorrow.
cheers
Mark
cheers mark,
Ive set up the gazebo and the car is under all ready to work on the rear end, discs and pads came today too and all the tools are clean and ready to use so should be good, cheers for posting it off, if it comes tomoz ill get to the front on sunday all being well, if not there is next Mon/Tues as I not sending the car in for the CV boot and Brake fluid change till I get back from Cornwall as I picking up some Iridiums and 1l of Motul DOT 5.1 fluid from Opie Oils seen as the GF family live just past them so gettin it on way there lol.
then she goin in on the monday we back. gives me time to scrub everything and do a good job getting all the underside cleaned up and painted.
Thank god I have a push Bike lol
cheers again Mark,
Billy
