LED Sidelights
Now I've never had a car which can detect lights are out and I presume on my 03 fabia vrs it will?? Just want to be sure as I want to update the lighting to these, just wondered if they would work??
leds
thank you!
it does detect when the bulbs are out should work fine with the leds as its just picks up a broken circuit
Ah cool. Just wondered as I did a search and some of the posts seem to suggest that they might not work properly. Coolies!
I read that you need to get some LED's with resistors in, also they have to be metal coated so they don't melt?
These are the ones you want - SO Bright!
Got any pictures?? just after ones which illuminate the entire section they're in as i had some led sideies on my lupo and they only really shone forward as opposed to lighting up the headlight if you get my meaning??
