Strange erros on new vRS
After tweaking a few settings on Saturday everything appeared to be ok, all the changes where working and the post change scan looked ok, I've gone to change one of the settings tonight and am getting the following scan results on module 9 & 46.
The strange thing is everything appears to be working correctly apart from talking to these two modules.
Any help greatly appreciated.
Monday,25,January,2010,18:50:29:56271
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z8A2074635
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RD HW: 03L 906 022 GA
Component: R4 2,0L EDC G000SG 5751
Revision: 13H03--- Serial number:
Coding: 0001072
Shop #: WSC 73430 790 00999
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B601C092900FE681106E7901E0082340800
Address 08: Auto HVAC (J255) Labels: 3T0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK35.rod
Address 09: Cent. Elect.
Cannot be reached
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2HHCP-
Coding: 0020788
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 J HW: 1Z0 920 943 J
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 410B00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K09C1002EB
Coding: E9807F06000202001303
Address 25: Immobilizer (J334) Labels: None
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000756
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8181103
Coding: 050004000001
Address 62: Door, Rear Left Labels: None
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
End ---------------------------------------------------------------------
Edited by McScooby
I've been able to sort this by running the scan when the doors arn't locked. :wonder:
Not sure why that would render the module unreachable but it sorted it.
Edited by McScooby
