Screenwash light.
I have the fl vrs with Maxidot. Two weeks old and just ran out of screenwash. I thought I would have had a warning light flash up to tell me I was low but none did. Is this the case on Octavias?
Exactly the same as me. I also asked the same question!
Apparently you only get the warning if your car is fitted with Xenons with the larger screenwash tank. Shame really :thumbdown:
You can retrofit the sensor and the bigger tank. A few have done it.
Is it easy done?
Bumper off, fit new bottle, bumper back on.
The following is for a Fabia. You'll need the correct part numbers for the Octavia, but should be a similar process.
  • 2 years later...
Hi, apologies for the thread-revival, but does anyone have any info on retrofitting the larger reservoir & sensor to a fl octy, please? Thanks.
Seems a bit pointless, but if it could be done for something in the region of £25 I'd be interested.......
