Plenum Chamber
I'm sure this question has already been asked, but having searched through the whole forum, I haven't found the answer. I've discovered info on the location of the pollen filter (under glove box); is this the same location as the plenum chamber?
Plenum Chamber will be in the engine bay, it's something do with the air intake system... (If my memory serves correctly)
A plenum chamber in this context is a box for holding "treated" air". There will be one for the ventilation system (maybe 2 with some air-blending systems), and another one for the engine intake (and arguably 2 when we count the standrd air filter box).
Can anyone let me know exactly where it is placed on the Octy2, please?
Edited by abuelo
  • 15 years later...
The plenum,as i understand, is directly under the engine cover, it's the collection of pipes that direct air to the intake manifold. On mine, it's a big plastic flow chamber.
What i want to know is, does it have a gasket and seal kit needed,as i want to clean up the rocker cover and check the pcv valve and pipes etc?
Edited by tonedcos
