Actuator help
Think i need a new actuator for the octy vrs i can get one off a mate but its from a k03 turbo?
what i need to know is are the ko3 and ko3s actuators the same? and can you change it in situ rather then having to take the full turbo off.
Thanks lee
Because the 1.8T has a PWM valve, there's every chance it could work.
Best way to be certain is to get a look at the part number on your current actuator, and the new one. You never know, the fitment could be slightly different between the two.
No idea if you can change them in situ or not, but I would hope so.
you can change in situ no probs and as far as i know there the same item if not get a forge one :thumbup:
cheers lads :thumbup:
i will probs get a forge one just a mate has a good used one that i want to try first to make sure i dont waste £100
