central locking will only open but not lock here are the vag com stats argggghhhhhhh
As the title says, want to sell this car now and listed on ebay then this happened with the central locking and now its not looking good. the central door locking only opens but doesnt lock the doors.
Here is the vag com stuff...
Address 46: central conv
part no: 1j0 959 799 l
component: 0z zentral-sg komf.0002
coding: 04096
part no:1u6959802b
component: 5b torsteuerger. fs0001
part no: 1u6959801b
component: 5s torsteuerger. bf0002
part no: steuerger
component: t hl antwortet nicht
part no: 1u0959812a
component: 0z torsteuerger.hr0022
8 faults found:
01329 - convenience system data bus in emergency mode
35-10 - intermittent
01333 - door control module, rear left (j388) no communications
00928 locking module for centaral locking front drivers side (f220) implausable signal - intermittent
00912 window regulator switch front left (e40) implausable signal - intermittent
00913 window regulator switch front right driver (e81) implausable signal intermittent
01035 electric window thermal protection active, front passenger - intermittent
00929 locking module for central locking, front passenger side (f221) implausable signal
00931 locking module for central locking, rear right (f223) implausable signal
Dont know where to start with this lot or if i have the will to start. Nightmare.
Thanks for any help on this.
Edited by justinbarrow
water in one of the front window regulator units? or a broken wire to the rear door, whats gone on with the roof?? does it really look as bad in the flesh, asking as i have started the bidding for you and wouldn't mind it a s a car for the missus if it is cheap enough
Edited by felicia16v
i would just contact any bidders mate and tell them about the fault and ask if they still want the bid to stand, and if anyone jumps in at the last second then tell them after and if they dont want it offer to next bidder, just replaced my bid as i now know the faults..
