1.2 htp starting problems
helle there, iam having starting problems on my fabia,its happening after cold night,freezing temperature,it wont start first time,second time is ok,sometimes start to wiggle then turns on,or i have to help him with accelaration.....
I have done diagnostics test few weeks ago,all errors was deleted [lamda sonda fault,imobiliser] after few miles get scanned again,with no errors.It was fine for 2 weeks,now problem still exist. I ve changed spark plugs,all filters..After switching ignition on and trying to start engine shows ABS light for couple of seconds,then it is comming off.
Any suggestions?
thank you
Tired battery I would think.
And what about errors on diagnostics?Does it mean anything.I think engine shoud start even in freezing temperature no matere what.
Do i have to replace battery?I was thinking maybe fuel pump,or engine temperature sensor.
Can it be front lambda sensor?it was on diagnostics faulty.
Any ideas?thanks
Any ideas?thanks
I ve put car on VAG for scan showing no faulty codes.
Anyone???
