Brake bleeding order
I have always used furthest wheel from m/c then work towards closest...
Apart from, I remember doing a SEAT where on elsawin VAG specified a different order (front then rear) because of something to do with the ABS system.
Anybody know about the octavia?
I always thought the same as you...
This might help:
Bleeding Brake System
Special tools and workshop equipment required
t Brake filling and bleeding device, e.g. - VAS 5234- or -ROMESS S15-
NoteIf one chamber of the brake fluid reservoir has run completely dry (e.g. leakage in the brake system) first of all a pre-bleeding of the brake system must be perfomed.
Bleeding (of air)
– Connect the brake filling and bleeding device.
Bleeding sequence:
1 - Bleed together and simultaneously the front left and front right brake caliper
2 - Bleed together and simultaneously the rear left and rear right brake caliper
– Leave the bleeder valves on the plugged-on hoses of the bleeder bottle open for as long as is takes until the bubble-free brake fluid flows out.
Then bleed the hydraulic unit once again via the function “Basic setting” at the diagnostic, measuring and information system-VAS 5051 -.
Initiate the basic setting (for bleeding the brake system):
– After this, the brake system must be bled normally.
Bleeding (normal):
Observe the work procedure for bleeding the brake system.
– Open the bleeder valves in the prescribed sequence and bleed the brake caliper.
1 - Front left brake caliper
2 - Front right brake caliper
3 - Rear left brake caliper
4 - Rear right brake caliper
Use a suitable bleeder hose. It must sit tightly on the bleeder screw so that no air can find its way into the brake system.
– Leave the bleeder valve of a brake caliper on the plugged-on hose of the bleeder bottle open for as long as is takes until the bubble-free brake fluid flows out.
After-bleeding
The assistance of a 2nd mechanic is required:
– Press down the brake pedal strongly and hold it there.
– Open bleeder valve at brake caliper.
– Push the brake pedal down to the stop.
– Close the bleeder screw if brake pedal slightly depressed.
– Let the brake pedal go slowly.
This bleeding procedure must be carried out 5 times for each brake caliper.
Bleeding sequence:
After bleeding perform a test drive. While doing so perform at least one ABS adjustment!
  • 6 months later...
Do you remember where you got this information from by any chance...?
Thanks a mil
  • 5 years later...
This might help:
Bleeding (of air)
Bleeding sequence:
Then bleed the hydraulic unit once again via the function “Basic setting†at the diagnostic, measuring and information system-VAS 5051 -.
Bleeding (normal):
After-bleeding
Bleeding sequence:
Could you pls. provide the source of this info; thanx in advance.
Edited by zzonyx
