Which Columbus for a FL Octy?
What's the correct part number for a Columbus to go in a FL Octy?
Should it be 3T0 035 680B rather than a 1Z0 version?
it's the same as the pre fl..possibly need a new facia though
The Correct part no. is a 1Z0
3T0 will work but you can run into coding issues.
You will need to order the correct facia surround which incorporates the new style aircon etc.
If i get chance over the weekend i'll dig out the correct part no's for you
Carl :thumbup:
I'd appreciate that, thanks. I was led to believe a 1Z0 would suit a pre-FL but a 3T0 would be better for the FL?
Either or will work
You just MAY get coding issues with the 3T0 unit. I'm pretty sure that a 3T0 is a superb unit only but i may be wrong.
By that i mean it may not be plug and play and require a bit of extra coding but it will still work
A 3T0 will even work in a Pre-FL
Carl :thumbup:
Any update on this?
is this correct the 1Z0 is the best unit suited for a FL octavia?? is there any difference in functionality form the 3T0 ? Cheers
I am now under the impression that it is the 3T0 as the Superb and FL octy share the same nav unit.
Thats why my research has thrown up. Hopefully its correct as I have a 3T0 unit sitting in the shed waiting to be fitted!!
3T0 for FL & Superb, thats what I fitted & all is gravy............
Any further on this - has anyone run into coding issues going from Bolero to 3T0? I have PDC, Climate and bluetooth on the display of the bolero and also have maxidot.
Thats because Red is the best colour!
I know that the 3T0 is what comes from the factory now but I was wandering about coding as i presume that the parking sensors and bluetooth will need coding.
