Turbo Noise
Hello, when i start my fabia from cold the turbo makes a noise like a Police siren, however after a run and its has warmed up the noise stops? is this normal? thanks Glenn
No not normal. Check for a boost leak, if no leaks found, get ready for new Turbo as the bearings will be about to fail.
Edit: If possible, it is better to replace the turbo now, before it goes bang. That way, you don't have to dig bits out of the inter-cooler, and also avoids possible engine/cat damage
Edited by MoggyTech
Snap
My mates Golf did this, shortly afterwards...POP. And it whined like a police car loudly, 24/7
It'd snapped a fin off the turbo.
Edited by CJS-90
i agree with the last 2 posts, definately not normal. my mates turbo made a whinning noise, it had bent the shaft.
oh and when mine went it cost 1500 because i also damaged the intercooler..if it needs replacing do it asap. :thumbup:
Amen to that. My mate got his sorted for about £500 in total, used turbo off eBay (covered like 40k miles, wheras his had done 130k), and fitted for £200 or something.
