Door card rattle of win!
Everytime i play music above about volume 3 the bloody speakers vibrate the door card...am i assuming this is a quick fix with a bit of sound deadening, loft insulation looking stuff :)
If the door cards rattling, then it needs securing better, sounds deading material wont help with that, take the door card off and see how to secure it better, i used some double sided carpet tape on the door with mine, helped somewhat pain in the arse to remove tho....
If i remember rightly this happens because the door card is too close to the speaker.
I think if you take off the bottom of the door card, and stick some cloth maybe, or even a little block of polystyrene in there, just to push it out a teeny bit, you should be fine.
I keep meaning to get around to doing this with mine.
