Noise when driving
I recently changed my disc and pads but still keep getting this noise as if there is grinding of disc etc. When i turn steering toward right the noise level increase dramatically. The steering vibrates alot and the pedals which makes the drive uncomfortable. Any ideas?
It could be a wheel bearing....
Could be a drive shaft CV joint!!
If you removed the outer part of the caliper from the inner part when you changed the discs and pads you might not have bolted them back together straight when you put the guide pins/bolts back in. This happened when we changed the rear discs and pads on my mates VRS, the outer part of the caliper wasn't straight and was catching the disc.
