Slight driveshaft VS turbo issue
I think the driveshaft would win. Photo taken on initial fitting, and YES, it is touching! :D
However, luckily the cold side could spin and be "stopped" in any position so it was swiftly moved. I didn't half panic when I first saw the outlet position! :giggle:
That is all, for now. Some more pics for the blog later
don't forget Jason, the driveshaft will move up and down with the movement of the suspension
and also slightly side to side when steering, so make sure there is loads of room, otherwise you may have issues
Edited by ric04vrs
That would have been too close for comfort Jason :)
Yeah - It is now absolutely miles out the way now. We had to also adjust the bracket for the actuator for this very reason. It cleared, "just" up and down but with the steering thing as well, some more modification was needed.....
