Daylight driving lights
Hello, Can someone please tell me the correct way to turn on the bottom running lights.The way i have turnd them on is by turning on the sidelight switch,but in the manual it says you turn on ignition without turning the light switch out of the position 0. Then to pull the signal light lever towards the steering wheel up to 3 seconds,slide to the top for 3 seconds. I must be doing something wrong because i cant seem to work it out. Thank you.
The stalk method works for my FL Scout - but it turns on dipped beam rather than any 'special' bulb.
I assume that you mean the LED strips between the main headlights and the fog lights.
On my car I just leave the main light switch on auto. The LED's light up all the time and the headlights come on as required. If you don't have auto headlights I'm not sure how they work.
